Receive midi clock per patch?
Hey.
Is it possible to filter out the midi clock from one or more patches?
I have different hardware here i control from the E1 thru Midi 1 out to a midi splitter but my Torso S4 with current firmware is not so midi smart (hopefully they fix it soon).
However it can only receive one midi message at a time which when sending midi clock to it fuck with every thing else i have set up etc.
So my question is :
Is it possible to make the patch ignore midi clock? so i can send clock to the other machines?
Either with a bit of lua or some setting i havent stumbled on?
Maybe even via a momentary button that can turn the clock on off for a moment (so i can sync the damn thing and then turn the clock of it sets bpm after it i think)
Kalle
I am planning to add a simple message filter and channel remapping to the router. That would do the job. Currently, it cannot be filtered out, even the Lua will not help - the message routing is independent from the presets :frowning:
yeah the easier the better :slight_smile: if it was not for Torso´s at this point pure midi implementation i would never have thought about it :smiley:
