apologies but again I can’t find something about the topic in the subject in the documentation nor searching this forum.
Can MIDI Learn be used for SysEx messages? The manual somewhere says:
Always try to twist the knob all the way to the left and then to the right. …
I tried using it this way but as a result it just stores the last recognized parameter, not a range.
If this visual editor would have been part of the manual I’d maybe able to work with that but I can’t by far get the idea intuitively, sorry.
I read the part with SysEx templates but to be honest I would avoid diving into this coding stuff and had the hope I can work without this for the very beginning using E1.
My goal is to have a range from 0 to 1023 using the following start and end SysEx commands:
F0 … constant bytes … 00 00 F7
F0 … constant bytes … 07 7F F7
The last two bytes contain the value.
If I am missing some already written answers or part of the documentation I’d really appreciate related hints or some common advice that might help me get started.
Thanks in advance!
BTW: I would really like to see a documentation that can be searched for specific terms entirely. As a workaround I already exported the current version to a PDF which took quite some time but the text is somehow weirdly encoded and the search within the PDF doesn’t work for most cases.
