Sysex pass thru?
Can sysex be made to pass thru the E1?
Other wise you need a midi merge box with 3 ins feeding the synth you want to control.
1 for the E1 output, 2nd for the sequencer input and 3rd for passing sysex patches from the computer.
if the E1 could pass sysex for patches from the computer then a lot of un/plugging midi cables could be saved.
Maybe you could use something like Midi Lab to avoid the Hardware (Midi Merge box)
http://en.soundigy.com/midilab.php
Yes, Electra does pass sysex messages (and other midi messages) by default. Anything send to USB port Port 1 is forwarded to port MIDI I/O 1, port 2 works in the same way. And it works in both directions, you can send sysex like this but also receive.
I ran into a weird problem, where electra is adding “line-breaks” to the sysex data. Every 32 bytes there is a F7 added. Is this normal? The sysex dump comes from a Prophet VS.
here is it captured with a motu midi express and with the electra.
00:41:39.967 From Electra Controller Electra Port 2 SysEx F0 01 0A 00 0E 0C 0D 01 00 03 04 06 00 00 00 00 00 00 00 0C 03 08 05 05 02 00 00 05 00 08 03 01 F7
00:41:39.990 From Electra Controller Electra Port 2 Invalid 00 0D 01 01 05 09 00 0D 02 05 01 0C 07 02 09 00 08 00 00 00 06 09 05 07 00 0B 0A 08 06 03 07 0C 0C F7
00:41:40.011 From Electra Controller Electra Port 2 Invalid 00 04 00 00 00 00 01 04 09 0C 03 0E 0B 0E 09 07 06 0E 04 0C 0D 07 0B 0F 0A 0D 0D 01 00 0A 00 07 02 F7
00:41:40.032 From Electra Controller Electra Port 2 Invalid 00 00 00 0F 00 00 01 04 09 00 00 01 0A 04 04 00 0F 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 01 0A F7
00:41:40.056 From Electra Controller Electra Port 2 Invalid 00 04 0B 04 04 0E 0E 00 00 0E 0C 02 08 00 0D 09 0C 00 00 00 00 0C 00 0A 04 01 06 00 00 00 08 00 06 F7
00:41:40.060 From Electra Controller Electra Port 2 Invalid 00 00 00 02 06 06 0A 00 00 F7
|00:44:41.843|From Express 128 Port 8|SysEx||F0 01 0A 00 0E 0C 0D 01 00 03 04 06 00 00 00 00 00 00 00 0C 03 08 05 05 02 00 00 05 00 08 03 01 0D 01 01 05 09 00 0D 02 05 01 0C 07 02 09 00 08 00 00 00 06 09 05 07 00 0B 0A 08 06 03 07 0C 0C 04 00 00 00 00 01 04 09 0C 03 0E 0B 0E 09 07 06 0E 04 0C 0D 07 0B 0F 0A 0D 0D 01 00 0A 00 07 02 00 00 0F 00 00 01 04 09 00 00 01 0A 04 04 00 0F 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 01 0A 04 0B 04 04 0E 0E 00 00 0E 0C 02 08 00 0D 09 0C 00 00 00 00 0C 00 0A 04 01 06 00 00 00 08 00 06 00 00 02 06 06 0A 00 00 F7|
I am looking at it now. Just so that I understand.
This messages received with your MIDI Monitor from E1 USB interface (port 2). You have Prophet VS connected to MIDI IO 2 connectors on E1. MIDI IO is configured to forward to USB device. Is that correct?
And this is when you connect Prophet VS directly to Motu interface?
What version of the E1 firmware are you running?
That is correct. The midi cable from the VS goes into E1 Midi In and then via USB to MIDI-Monitor. I’m using E1 as a USB interface. Is the midi buffer very small and is dividing the message?
Thank you for looking into it.
The bigger problem with the VS is his weird implementation of NPRN. MSB and LSB are switch but as well the parameter select bytes are in reverse order. :confused:
E1 forwards a stream of packets (midi bytes). There is basically no limit on forwarded messages. It must be something else. I just tried to forward 4kB messages (from MIDI IO → USB dev)
(note USB MIDI cable is a USB to MIDI IO converter. So, E1 received MIDI data via MIDI IO DIN)
I will keep looking at it and thinking what it could be.
