Hey i know this have been asked many times but i can´t find out if its possible without writing Lua.
Can i use the pot touch to send a midi cc message ? and if yes how do i actually do it?
Sorry i am ultra noob with the E1 ![]()
You’ll need lua for this.
But yes, you can have it send a midi CC message upon touching if that’s what you want. It’s using a subscription to touch events and a ‘onTouch’ callback that you can invoke when the pot is touched.
I myself haven’t done that yet.
Thx for the answer.. i was afraid it involved lua better learn the basics of it but is not so sharp at coding in general.. this might be the perfect reason to do it ![]()
Yes, the ‘onTouch’ callback is very useful and I have used it in my recent presets. I was switched on to it by @oldgearguy.
Here is a snippet of lua code from one of my recent presets (Electra One App). This is sending sysex rather than cc messages, but its the same basic idea.
-- events to track
events.subscribe(PAGES | POTS)
-- curCtl holds which of the control knobs were touched
-- only want to update after the control was changed and then released so
curCtl = -1
-- control Ids ordered by parameter number (201-218)
patchCtls = {186,188,189,190,191,192,199,202,204,206,6}
msbIdx = 95 -- msb for SN Synth tones
lsbIdx = 64 -- lsb for SN synth tones: (64-70) for factory patches, and (0-3) for user banks
local idx = get_key_for_value(patchCtls,controlId)
if (idx == nil) then return end
if (touched == true) and (curCtl ~= controlId) then
curCtl = controlId
if (touched == false) and (curCtl == controlId) then
local midiValue = controls.get(controlId):getValue("value"):getMessage():getValue()
local s = parameterMap.get (deviceId, PT_VIRTUAL, 10000 ) + 31
local lsb = math.floor(midiValue / 128) + lsbIdx
local midiValue = (midiValue % 128)
-- SNS patch select
local array = {0x41, integra_ID, 0x00, 0x00, 0x64, 0x12, 0x18, 0x00, s, 0x06, msbIdx, lsb, midiValue, 0x7F}
midi.sendSysex(port, array)
-- request SNS patch data
local ab = SNAddress(1)
array = {0x41, integra_ID, 0x00, 0x00, 0x64, 0x11, ab[1], ab[2], 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x7F}
midi.sendSysex (port, array)
-- currently do not need to track which page is active; we might need it later
function events.onPageChange(newPageId, oldPageId)
return
@kiwigrass thx a lot i will read thru this 100 times to see if i will learn something
i am really bad with code and have always wanted to understand at least basics..
