I am testing out the latest beta firmware 3.0.12
I also pulled the latest commits from git.
It seems more responsive but still crashes:
I am selecting some tracks one by one. It shows the SSL plugin.
Then I select the master track and the E.one crashed.
I do have dumps enabled as I want to make templates.
The mixer was only visible at start.
Ableton logs
2023-01-25T12:18:38.827601: info: RemoteScriptMessage: E1 (debug): - Uploading device PluginDevice
2023-01-25T12:18:38.827612: info: RemoteScriptMessage: E1 (debug): -- Getting preset for PluginDevice.
2023-01-25T12:18:38.827620: info: RemoteScriptMessage: E1 (debug): -- Constructing preset on the fly...
2023-01-25T12:18:38.827648: info: RemoteScriptMessage: E1 (debug): -- Dumper for device PluginDevice loaded.
2023-01-25T12:18:38.827934: info: RemoteScriptMessage: E1 (debug): -- Filter and order parameters
2023-01-25T12:18:38.828001: info: RemoteScriptMessage: E1 (debug): -- Construct CC map
2023-01-25T12:18:38.828497: info: RemoteScriptMessage: E1 (debug): -- Construct JSON
2023-01-25T12:18:38.830317: info: RemoteScriptMessage: E1 (debug): -- dumping device: PluginDevice in C:\Users\Tim Bos/ElectraOne/dumps/PluginDevice.epr.
2023-01-25T12:18:38.831129: info: RemoteScriptMessage: E1 (debug): ** Upload thread starting...
2023-01-25T12:18:40.022203: info: RemoteScriptMessage: E1 (debug): ** Upload thread requesting MIDI map to be rebuilt.
2023-01-25T12:18:40.022238: info: RemoteScriptMessage: E1 (debug): ** Upload thread done.
2023-01-25T12:18:40.065512: info: RemoteScriptMessage: E1 (debug): - Main build midi map called.
2023-01-25T12:18:40.065530: info: RemoteScriptMessage: E1 (debug): - EffCont building effect MIDI map.
2023-01-25T12:18:40.065801: info: RemoteScriptMessage: E1 (debug): - EffCont effect MIDI map built.
2023-01-25T12:18:40.065818: info: RemoteScriptMessage: E1 (debug): - EffCont refreshing state.
2023-01-25T12:18:40.450383: info: RemoteScriptMessage: E1 (debug): - EffCont state refreshed.
2023-01-25T12:18:40.450416: info: RemoteScriptMessage: E1 (debug): - MixCont building mixer MIDI map.
2023-01-25T12:18:40.450432: info: RemoteScriptMessage: E1 (debug): -- Building transport MIDI map.
2023-01-25T12:18:40.450448: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track Master.
2023-01-25T12:18:40.450499: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track A-Reverb.
2023-01-25T12:18:40.450523: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track B-headpones.
2023-01-25T12:18:40.450543: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track 1-MIDI.
2023-01-25T12:18:40.450603: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track 2-Audio.
2023-01-25T12:18:40.450648: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track 3-Audio.
2023-01-25T12:18:40.450690: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track 4-Audio.
2023-01-25T12:18:40.450732: info: RemoteScriptMessage: E1 (debug): -- Building MIDI map of track 5-Audio.
2023-01-25T12:18:40.450773: info: RemoteScriptMessage: E1 (debug): - MixCont mixer MIDI map built.
2023-01-25T12:18:40.450781: info: RemoteScriptMessage: E1 (debug): - MixCont not refreshing state (mixer not visible).
2023-01-25T12:18:44.644099: info: RemoteScriptMessage: E1 (debug): - Assigning an empty device.
Device template
PluginDevice.epr (18.5 KB)
After reconnecting the usb cable the e.one came back to live/life ![]()
Then I wasnât able to replicate the crash.
The other issue is with vst3âs. sorry to bring it up.
But it seems on windows work differently.
Adding a vst3 to an Audio Rack and save it under the name âSSLâ does not create a template name âSSLâ but âProxyAudioEffectDeviceâ.
So it is not possible to make presets for other devices as it creates the same issue like when its creates âPluginDevice.eprâ for vstâs.
It it is much better to use the real device name on Windows.
Because in the current state we can have only 1 vst âŚ
Like that we can have at least a default template for each vst.
Anyhow I will try to look deeper into this to find a sollutions.
There must be a way.
Below are 4 different prestets selected. On my Ableton Push I see the same name which is the actual plugins name not the preset namesâŚ
