I am not getting the dump to work and the sendmidi neither.
LIBDIR = r'C:/Users/SomeUser/eOne'
# This worked in the very old script
#LOCALDIR = r'E:/Ableton User Lib/User Library/Remote Scripts/ElectraTwo'
# === FAST SYSEX UPLOAD
# Flag whether to use fast sysex uploading,
# using the (external) sendmidi package
# If True, correctly set the following two constants too
USE_FAST_SYSEX_UPLOAD = True
# path to the sendmidi command, relative to local library directory (see LIBDIR)
SENDMIDI_CMD = r'./lib/sendmidi.exe'
# full path is C:/Users/SomeUser/eOne/lib/sendmidi.exe
# name of the Electra One port to which to send the SysEx command
E1_CTRL_PORT = 'MIDIOUT3 (Electra Controller)'
2023-01-19T19:20:37.684352: info: RemoteScriptMessage: E1 (debug): - Fast uploading of presets not supported (command not found), reverting to slow method.
2023-01-19T19:21:01.598497: info: RemoteScriptMessage: E1 (debug): â Filter and order parameters
2023-01-19T19:21:01.598551: info: RemoteScriptMessage: E1 (debug): â Construct CC map
2023-01-19T19:21:01.599058: info: RemoteScriptMessage: E1 (debug): â Construct JSON
2023-01-19T19:21:01.601048: info: RemoteScriptMessage: E1 (debug): â dumping device: PluginDevice in C:\Users\SomeUser/dumps/PluginDevice.epr.
Note the home dir part and the rest⌠Doesnât make a difference what you set in config.py. Looks the homedir is a variable
One little thing I noticed. I have a Live set with many audio tracks and each with the channel EQ plugin. When I remove a channel, E1 is updated correctly, but it gets automatically switched to the Channel Eq preset of the previous track. I would kind of expect to stay in the Mixer presetâŚ
Yeah, I know. This is partially covered by the SWITCH_TO_EFFECT_IMMEDIATELY and APPOINT_ON_TRACK_CHANGE configuration constants, but not ideal yet. (And anyway not guaranteed to work if you have other controllers attached with their own device appointment routine)
Hi ,
thank you @Flyweight for your help but I didnât succeed with SendMIDIâŚ
Iâll try again later⌠Never give up
I especially wanted to see if the data download was faster.
Currently for EQ8 itâs 3-4 seconds itâs already very good butâŚ
I noticed that the PRESET REQUEST button does not switch to the device preset. It only switches from preset to mixer for me. is it the same with you?
Otherwise, I briefly had the problem of âfader suddenly jumps back to zeroâ I reset E1 and everything was OK (I have a video and log if you want). Is it better to post log & bug reports here or on @jhh Github?
Switching should work both ways indeed. Did you upload the latest version of the mixer preset (Mixer.eproj in the repository) to the correct slot (6th bank 1st slot)?
I added an alternative mixer design that shows the transport controls on al mixer pages. See Mixer.alt.eproj. To use it, copy config.mixer.alt.py to config.py.
Unfortunately, the Plugin Device does not work since 3-4 updates. it worked perfectly until then. no longer for the last 3-4 Scripts. Plugin device preset is not even created in E1. The latest mixer preset is in the right place (bank6, p1), I didnât change anything, only the color of the plugin device, and I turned off the âautomatic switchingâ. What could be the reason?
itâs hard not to be able to help you other than to show you the problems⌠thank you so much Jaap.
Yes, I checked, it is in bank 6 slot 1.
I tried quickly on the Mixer.alt.eproj and itâs the same.
PRESET REQUEST ne marche pas.
Tried to build a new Vinyl Distortion presets
and modify some existing presets. Now any preset is not uploaded to the E1 slot 2, is empty.
Iâm going to reset E1 tonight.
ps: I just saw that @phonaak has a similar problem. business to followâŚ
Hi, I just uploaded 3.0.12 firmware to beta.electra.one. It is mostly result of working with @jhhâs remote script on both Mac and Windows. Along with work on the firmware I also proposed a small change to the remote script. I leave it up to @jhh if he incorporates it in his work.
I am currently (3.0.12 + altered remote script) getting a very smooth experience on MacOs and Windows 11. I use it without sendmidi as I did not see much difference in my setup. I can use sendmidi on MacOs without problems. On windows, I was able to configure it but the single-client issue prevents using sendmidi and Ableton in the same time. Ableton acquires the connection and sendmidi cannot transfer then. I am still looking at it though. I am not a Windows power user, so I need to get used to it a bit firstâŚ
I will be busy with windows for the rest of the day today, and I will be looking at the value jump issue.
The last fw with the last Script works fine. unfortunately, the faster midi communication does not work (?)
I set everything in the config.py file, as it was âshownâ in a comment before, but the plugin device is just as âslowâ. of course, it still works, and I donât really use it, but I was curious.
