if you enable dumps in config.py there will be a dump of the template and the ccmap.
the default is C:\Users\Yourusername\LIBDIR
LIBDIR is also set in config.py, so the default electraone.
So create:
C:\Users\Yourusername\electraone\dumpdir\
ccmap and templates can be found there.
The ccmap is not needed to make your template in the e.one app.
You will notice in the app the templates have raw data notation.
But the lua functions and the remotescript will take care of it.
So you will see HZ, DB , switch names etc.
Only issue is you need to take care of the parameternumbers in the template and the ccmap match.
I have issues with this. Looks the app.electrone is changing them.
Especially when you copy and paste. I will try to report this more precisely later.
If you enable dumping (DUMP=True), the .ccmap and .epr (E1 preset) are created automatically and written to the ./dumps directory in the directory specified by LIBDIR. You should then be able to import the preset (.epr) in the web editor.
Note: logging has been changed using new 3.1 features, no need to use MidiPipe any more for this either. New option E1_LOGGING_PORT can now be used to redirect E1 log output.
Moreover, I believe there was a bug in the code managing acts/nacks that may have been the cause of what went wrong on your side. This has now also been fixed. Please confirm that you can now again upload presets for your plugin device.
Thanks for your quick responses @jhh ,@Flyweight .
I manage to get the dumps with .epr and .ccmap in folder.
I continue my laborious learning and I still have problems⌠I donât know what Iâm missing despite the efforts of writing on @jhh the md.readme.
Now I want to create a preset for the Operator device :
I upload the .epr file from /dumps on the Electra editor
I put some order and some colors
I download the Operator.epr file
-I place it with the .ccmap in: user C:\Users\MoW\Documents\Ableton\User Library\Remote
Scripts\ElectraOne\preloaded
-I launch Live 11 and I donât see the modifications made on the editor, the Operator.epr/ccmap file is created again in the /dumps âŚgrmfâŚ
For the previous problem :
I donât follow myself well, sorry: itâs when I use the âupload from electraâ function (electra ap>controler>presetslot). Only on presets like Ultraanalogue or Eq 8. ⌠it still doesnât work for me. It was a workaround. Otherwise the Dl works fine.
this doesnât work either. I set it up in config.py, there is no âAbletonâ folder in the âpreferencesâ folder. I tried e1 with port 0 and 2 as well.
with the latest Script, the plugin device preset is created when I switch with the upper right button, but the scipt âworksâ strangely.
there is no Macro in an omnisphere, if I click on it, the e1 a device on button also loads very slowly compared to before (10 sec). The loading indicator âanimationâ flashes several times. if I click on an ssl4000E, it just âblinksâ that it is loading, but even after 10 minutes of charging, nothing is shown on the display-. the e1 freezed
