here?
no Electra folder fere
Ok now do cd ./Library/Preferences/Ableton/
then there will be a version and then the logfiles etc.
Otherwise run pwd
copy this to your file browser.
This will get you to the logfile of Ableton.
For the remotescript, edit config.py and enable dumps.
if youâre in the Ableton folder search log.txt.
so you are close.
I donât find any other
No those are not related to the E1 Remote Script.
What happens if you type the ls command here?
In my case I would see several folders called Live 10.x.y here. Do you see that too?
@Flyweight does the latest version of the remote script work for you now, or do you still have issues?
Great! Type cd Live\ 11.2.7. Then type ls. You should see Log.txt (among other files). Thatâs the log file that includes the remote script debugging messages!
Start Ableton fresh. Do whatever you do to trigger the error. Describe to me exactly what you did to trigger the error and send me the contents of Log.txt. Maybe I can help.
I started ableton. the error also occurred with the first plugin, but ânothing happenedâ in the terminal window. the time of the last âlogâ remained 18:02
Did you do ls again?
Ah sorry, do ls -la to also show the modification times of the files
here
Great, Log.txt was changed at 19:34 so should contain the info I need. Please send it to me. And what exactly are you doing that fails?
