Hi. It’s not possible right now to change the value of a text label after you’ve created them.
For example I have this list:
0 = OFF
16 = LPF
31 = BPF
48 = HPF
64 = NOTCH
80 = COMB
I did create all the text labels for each value, but now I see that I’ve made an error: BPF should have value 32 instead of 31. The only solution now is to delete the COMB, NOTCH, HPF and the BPF label and input those 4 labels all over again.
It would be great if we could just adjust the value for BPF in my example.
EDIT: this works perfectly if I switch to import / export but not on the standard text label display
Hi. Nope that doesn’t work. If I adjust the value in the window you posted, the value changes but isn’t saved. Hence, when I return to edit the values the original value is back. I have to switch to the import / export window and there it works perfectly.
