Bootloader update
Version 4.0 introduces an easier way to update the firmware - directly from your web browser, just like with the mk1. To use this new update method, you’ll first need to update the Electra One bootloader.
The bootloader can be updated by the beta 4.0 (or later) firmware. Thus, in order to update the bootloader, the beta 4.0 must be installed in the usual way using the USB storage. Once you are running the 4.0, you can go to Electra One App to proceed with the bootloader update.
Important
I’ve run quite a few updates and everything worked fine. But since this is a bootloader update, there’s always a small risk of bricking the controller if something goes seriously wrong :slightly_smiling_face:
If you’re on Windows or Linux, we can recover it easily (i.e., un-brick it). If you’re using only a Mac, I’d recommend waiting until a few more users successfully complete the update.
Either way, if something goes wrong and the controller gets bricked, we (Electra One) will make sure it gets fixed.
If you decide to help us with this, feel free to ping me before you start - I’m happy to stand by just in case.
Hi Martin,
I gave this a shot but it seems to do nothing. The device shows “Uploading Firmware image” and the progress bar in the browser is stuck at 0%.
I tried with 4n, 4p and now 4s.
Cheers!
Hi @moss,
I just read what I wrote in the original message I an can see that I did not share the link to the bootloader update page :slight_smile:
In order to use the new firmware update, the bootloader needs to be updated first. And in order to update the bootloader, you must run any of 4.0 (the more recent the better).
ie. the steps to take:
  1. do conventional firmware update to 4.0.0… using the USB storage
  2. once the 4.0.0… is running, go to Electra One App and use it to update the bootloader
  3. after it reboots, use beta.electra.one/electra to update the firmware
are you stuck at the boot screen now, or can you boot your controller ok?
That’s exactly what I did. I am stuck on step 2 as described above. But I can reboot the device without a problem.
just to make sure. The page you use in step two is this:
I am double-checking because “Uploading Firmware image” means that the controller wants to do the firmware update, not the bootloader update.
Ah, sorry for the confusion! Yes, I ment Bootloader.
This is a set of sysex messages that facilitates the bootloader update. That is what browser sends to the controller to update the bootloader.
Could you try to run with a SysexLibrarian / MidiOX / or similar?
bootloader-update.syx.zip (277.4 KB)
While running, the controller will send back ACK/NACKs and progress report data.
This worked fine with good old MIDI-OX.
Output.txt (181.6 KB)
Input.txt (20.3 KB)
I am on Windows 11 Pro with all patches and used Google Chrome previously (also latest version).
I will give it a try. Thanks for testing it. You should be able to update the firmware directly from beta now - but I am quite sure that you will hit the same issue.
This is the output in the JavaScript console in Chrome when everything goes ok:
EDIT: @moss I was able to reproduce the issue on Windows. No need for you to do / review anything on your side. I will tackle that on my end.
@moss, would you try the bootloader and firmware update now? Windows does not like bigger chunks of MIDI data. Updated beta.electra.one uses smaller chunks now. If you do, make sure you hard-reload the page to make sure nothing is cached.
The upload of the bootloader file does work now but it is now stuck on “Validating update…”. I guess you need to adapt it to the shorter messages?!
Or maybe it is only the text that remains since in the browser it said “Bootloader update has been completed. You can leave this page now.”
I also tried the firmware update: my controller has 4r. Ther update seem to have worked but the browser still says that I need to update it. And it still says its 4r. Is therer a newer one?
I just tried this process and I keep getting “bootloader update failed” and I’m seeing "validation failed’ on my One.
I am having problems to replicate this one. I made some changes and I get consistent and correct updates on win / macOS / linux. Can you retry? And if it does not work, please share info about operating system and browser version. Thanks!
Was feeling lucky after a successful 4.0 update so thought to update the bootloader as well :laughing:
That didn’t work though, the upload (from Chromium) causes MIDI buffer overruns and then gets stuck at 30%. Since the actual update doesn’t even start here, just rebooting the Electra is enough to recover.
How big is the bootloader image? I have /sys/module/snd_seq_midi/parameters/output_buffer_size set to 262144 and this has been sufficient for other uses.
Edit: P.S. this is obviously non-urgent, I’m sure you’ve you hands full with other 4.0 related matters
@ pmatilai could you retry?
I made adjustments and tested the setup with macOS, Windows 11, and Linux/Kubuntu 25.04 (Chromium). It works fine for me on all three systems. I wanted to test it with Firefox on Linux, but I couldn’t get past enabling MIDI for the page - I need to review what’s happening there.
The transfers are done using 4096 bytes chunks to prevent issues with output_buffer_size on linux. If you open JavaScript console in the browser, you should see a few log messages for each chunk transferred:
The link to the bootloader:
Bootloader Update
The documentation:
Bootloader update docs
I would be happy for anyone to test it. I would like to release an updated firmware v4.0.1 but it is currently blocked as users need to update their bootloaders first. A few field tests would be great.
NOTE, if you purchased your Electra in May 2025 (or later), you already have the latest bootloader installed. No need to update now.
Yeah, I saw the earlier mention of changing it to smaller chunks so was a bit surprised those overrun errors. My Electra is from last October so not that new.
And ok, worked this time around like there was nothing to it :+1:
This was with Chromium of Fedora 42 (x86_64).
Couple of differences here: Last time I tried the update through the beta-site link earlier in this thread. Another difference was that this time I also rebooted the desktop machine before updating, just to be sure there are no ghosts in the machine or software. I wouldn’t be surprised if it was the latter that made the difference, this doesn’t get rebooted too often.
As for Firefox, there’s an unnecessary and annoying limitation in the Rust wrapper around the ALSA library causing it to reject large sysex messages. What’s especially annoying is that this was fixed in the midir wrapper ages ago but Firefox bundles an old version that doesn’t have what is literally a one-liner fix for this: 1965635 - Large MIDI sysex messages not working on Linux
