Is there a way to bypass “midi input” (I don’t know how to call that, midi feedback?) for a single control ?
My use case:
I have a on-off list control that I use to trigger, let’s say, an “effect rack” in Ableton Live: on(127) means “ON” and off(0) means OFF to that effect rack.
I map the same on-off list control that I use to trigger another effect rack, but this time on(127) means “OFF” and off(0) means ON to that effect rack.
This controls does enable the first rack and disable the second one when activated, and vice-versa.
The problem is that the control gets two opposite feedback info (one is 0, the other is 127) and is not displaying what it should be anymore (sometimes it’s correct, sometimes it’s not (displaying “off” instead of “on” for instance).
I know that for this particular use case I could find a workaround in Ableton Live, but for my actual use case it’s not possible.
So is there a way to tell Electra (or Ableton Live) to “silent” a particular midi control ?
Any idea?
Thanks!
