Exclusive midi output routing?
Hi!
Just got my electra one mkII and I’m thrilled as It feels like an amazing piece of controller.
I intend to use the drivenbymoss script and preset for reaper and bitwig, some other synths and to control my Hw electronic music setup witch is deluge centered, but a new idea popped in my mind.
Would there be a way to set a preset for controlling my rme fireface total mix using Electra’s midi out 2 in a way that would not mess things up when I use electra to control my other devices/App ?
What I think is I’d need to exclude the other electra’s presets from that midi out 2 port so I won’t end up messing total mix while controlling a synth on my deluge etc…
I’m not a programmer and sadely have not a huge amount of free time to learn to program either. Is there a way to set things up in a simple way ?
Vincent
Each MIDI port can send independent data to up to 16 separate MIDI channels. So the trick is to route the same midi port to multiple devices (using midi thru where necessary to extend the chain), and then program each device on that chain to listen to different midi channels. Then in your electra one presets, use the corresponding channel for each device.
Thank you for the reply.
Will try to get my head around that when I’ll have more time.
