Hi! newby here ![]()
I come from using Lemur for some time, and im finding it tricky to do some things…
I would like to have a slider that goes from -36 to +36, in 12v steps increments.
Im using this fader for setting up the octave of a midi pitch fx in ableton so it goes from -36 tones (-3 octaves, -2 octaves, -1 octaves, 0 octaves, 1 octave, 2 octave, 3 octaves) but i cant figure out how to do it.
Do i have to use the function menu? Do i have to declare variables?
Cheers
Welcome to the forum. I’m a user, just like you.
So you want to jump discrete values, do you?
I will assume:
- the control you want to do is plain MIDI CC, right?
- You know the values you want to send. They can’t be negative (MIDI CC will not allow you to do that), so it can’t for instance be -36, -24, -12, 0, 12… but rather 0, 12, 24, 36, 48, 60 where 12 stands for -24, 36 stands for 0, 60 stands for +12 etc…
Then create a list controller (not a fader), and populate its list with something as shown below
(forgive me the default MIDI value in my example, that should typically have been 36 in this case, not 30)
Hi! Thanks a lot for your reply and feedback! Got it working cheers!
