Has anyone created a preset that sends CC values as per an LFO? Variable waveforms, rates, etc? Is it possible?!
yep , there is one in my minitaur preset. It’s a pretty extensive one, mind you
Ah yeah I think you pointed me in that direction before (short term memory isn’t what it was
) I now remember looking at it and unfortunately my Lua isn’t remotely good enough to see how you’d implemented it. Thanks for the reminder, I might take another look
I think Martin also has made an LFO in a separate preset, you can then address in any other synth presets you have. This would even allow syncing modulation between synths without it being tempo controlled. Which is a very useable idea
Don’t suppose you have a link to Martin’s preset?
Don’t worry, ChatGPT has kindly extrapolated the LFO from your Minitaur preset so I’m using that as a starting point. Happy to share the preset once!
wow ![]()
Oops, I meant happy to share once it’s done!
Turns out Chat GPT is quite good at writing E1 code.
Here’s another one where I made a simpler LFO to work with the Korg NTS-1
I’ve added Martin’s lfo into my OB-6 and P-6 presets, it works rather nicely. In lua you’ll find all init variables for it in the top of the code, and the logic at the bottom of it. The lfo controls themselves are on page 11, including the scope. I’ve made the scope smaller than in Martin’s example, because the drawing of the scope has an impact on the lfo speed. The smaller the grap , the lesser the effect.
