I wanted to control my Pioneer AS-1 synth with the E1. For this purpose I installed the preset built by @Flyweight. However, when I dump the current synth preset data, the E1 freezes when I want to use a control. The controls are updated to the proper value once after the dump. I can also switch between rows without triggering the freeze. I tried 3 different synth presets with the same result. Can’t verify if this happens with any other device right now. In the logs I can read the following (from boot to freeze):
l), visible=1
21:39:13.676 parseMessage: device=1, msgType=nrpn (3), parameterId=1152, min=0, max=0, value=0, offValue=0, onValue=1, lsbFirst=0, signMode=0, bitWidth=14
21:39:13.677 parseValue: id=value, index=0, defaultValue=0, min=0, max=0, overlayId=0, formatter=(null), function=(null)
21:39:13.678 parseControl: id=105, name=SEQ LENGHT, type=list (3), mode=0, colour=529DEC, controlSetId=3, variant=(null), visible=1
21:39:13.679 parseMessage: device=1, msgType=nrpn (3), parameterId=170, min=0, max=0, value=0, offValue=-1, onValue=-1, lsbFirst=0, signMode=0, bitWidth=14
21:39:13.680 parseValue: id=value, index=0, defaultValue=0, min=0, max=0, overlayId=18, formatter=(null), function=(null)
21:39:13.681 parseControl: id=106, name=TIME DIVISION, type=list (3), mode=0, colour=529DEC, controlSetId=3, variant=(null), visible=1
21:39:13.683 parseMessage: device=1, msgType=nrpn (3), parameterId=163, min=0, max=0, value=0, offValue=-1, onValue=-1, lsbFirst=0, signMode=0, bitWidth=14
21:39:13.684 parseValue: id=value, index=0, defaultValue=0, min=0, max=0, overlayId=19, formatter=(null), function=(null)
21:39:13.685 Preset::parse: successfully loaded preset: name=Pioneer Toraiz AS-1, version=2
21:39:13.686 number of lua functions: 2
21:39:13.687 free RAM: free=150920, heap=15280, lua=0, collision=0
21:39:13.689 displayPage: page shown: page=0, controlSetId=-1
21:39:13.690 free RAM: free=135456, heap=30744, lua=0, collision=0
21:39:13.691 loadPresetById: preset loaded: name=Pioneer Toraiz AS-1
21:39:13.692 loadLua debug output:
21:39:13.693 ---- START ----
21:39:13.695 loadLuaModule: Lua extension file initialized: file=ctrlv2/p000.lua
21:39:13.696 ----- END -----
21:39:13.697 lua: function onClock does not exist
21:39:13.698 lua: function onStart does not exist
21:39:13.699 lua: function onStop does not exist
21:39:13.700 lua: function onContinue does not exist
21:39:13.701 lua: function onActiveSensing does not exist
21:39:13.702 lua: function onSystemReset does not exist
21:39:13.703 lua: function onTuneRequest does not exist
21:39:13.704 lua: function onProgramChange does not exist
21:39:13.705 lua: function onAfterTouchChannel does not exist
21:39:13.707 lua: function onPitchBend does not exist
21:39:13.708 lua: function onSongSelect does not exist
21:39:13.709 lua: function onSongPosition does not exist
21:39:13.710 lua: function onControlChange does not exist
21:39:13.711 lua: function onNoteOn does not exist
21:39:13.712 lua: function onNoteOff does not exist
21:39:13.713 lua: function onAfterTouchPoly does not exist
21:39:13.714 lua: function onSysex does not exist
21:39:13.715 lua: function onMessage does not exist
21:39:13.717 setup: preset loaded: name=Pioneer Toraiz AS-1
21:39:13.718 loadLua debug output:
21:39:13.719 ---- START ----
21:39:13.720 loadLuaModule: Lua extension file initialized: file=ctrlv2/p000.lua
21:39:13.721 ----- END -----
21:39:13.722 lua: function onClock does not exist
21:39:13.723 lua: function onStart does not exist
21:39:13.724 lua: function onStop does not exist
21:39:13.725 lua: function onContinue does not exist
21:39:13.726 lua: function onActiveSensing does not exist
21:39:13.727 lua: function onSystemReset does not exist
21:39:13.728 lua: function onTuneRequest does not exist
21:39:13.730 lua: function onProgramChange does not exist
21:39:13.731 lua: function onAfterTouchChannel does not exist
21:39:13.732 lua: function onPitchBend does not exist
21:39:13.733 lua: function onSongSelect does not exist
21:39:13.734 lua: function onSongPosition does not exist
21:39:13.737 lua: function onControlChange does not exist
21:39:13.738 lua: function onNoteOn does not exist
21:39:13.739 lua: function onNoteOff does not exist
21:39:13.740 lua: function onAfterTouchPoly does not exist
21:39:13.741 lua: function onSysex does not exist
21:39:13.742 lua: function onMessage does not exist
21:39:13.743 free RAM: free=110296, heap=55904, lua=21020, collision=0
21:39:13.744 setup: enable readMidi ()
21:39:13.745 scanUSBHost: device MIDI1 2b73:18: connected
21:39:13.746 - manufacturer: Pioneer
21:39:13.747 - product: Toraiz AS-1
21:39:13.748 Assigning new MIDI1 device to midiBus 0: Toraiz AS-1
21:39:13.749 processGeneralSysex: manufacturer 0
21:39:13.781 processElectraSysex::handleElectraSysex: electraInfo sysex sent to the host
21:39:13.787 processElectraSysex::handleElectraSysex: electraInfo sysex sent to the host
21:39:13.793 processElectraSysex::handleElectraSysex: electraInfo sysex sent to the host
21:39:13.797 processElectraSysex::handleElectraSysex: config sysex sent to the host
21:39:13.813 processElectraSysex::handleElectraSysex: preset sysex sent to the host
21:39:13.819 processElectraSysex::handleElectraSysex: electraInfo sysex sent to the host
21:39:13.824 processElectraSysex::handleElectraSysex: config sysex sent to the host
21:39:13.929 processElectraSysex::handleElectraSysex: preset sysex sent to the host
[LOG CLEARED?]
alue=0, extractedValue=0 to parameterNumber=167, type=nrpn resulting in parameterValue=0
21:39:54.753 ElectraMidi::processSysex: applying extraction rule: byte=13, byteValue=1, extractedValue=1 to parameterNumber=1, type=nrpn resulting in parameterValue=1
21:39:54.754 ElectraMidi::processSysex: applying extraction rule: byte=2, byteValue=36, extractedValue=36 to parameterNumber=5, type=nrpn resulting in parameterValue=36
21:39:54.755 ElectraMidi::processSysex: applying extraction rule: byte=15, byteValue=0, extractedValue=0 to parameterNumber=10, type=nrpn resulting in parameterValue=0
21:39:54.755 ElectraMidi::processSysex: applying extraction rule: byte=14, byteValue=1, extractedValue=1 to parameterNumber=11, type=nrpn resulting in parameterValue=1
21:39:54.756 ElectraMidi::processSysex: applying extraction rule: byte=18, byteValue=0, extractedValue=0 to parameterNumber=28, type=nrpn resulting in parameterValue=0
21:39:54.757 ElectraMidi::processSysex: applying extraction rule: byte=19, byteValue=0, extractedValue=0 to parameterNumber=29, type=nrpn resulting in parameterValue=0
21:39:54.758 ElectraMidi::processSysex: applying extraction rule: byte=20, byteValue=2, extractedValue=2 to parameterNumber=31, type=nrpn resulting in parameterValue=2
21:39:54.758 ElectraMidi::processSysex: applying extraction rule: byte=25, byteValue=0, extractedValue=0 to parameterNumber=47, type=nrpn resulting in parameterValue=0
21:39:54.759 ElectraMidi::processSysex: applying extraction rule: byte=29, byteValue=0, extractedValue=0 to parameterNumber=51, type=nrpn resulting in parameterValue=0
21:39:54.760 ElectraMidi::processSysex: applying extraction rule: byte=30, byteValue=0, extractedValue=0 to parameterNumber=52, type=nrpn resulting in parameterValue=0
21:39:54.761 ElectraMidi::processSysex: applying extraction rule: byte=50, byteValue=0, extractedValue=0 to parameterNumber=71, type=nrpn resulting in parameterValue=0
21:39:54.762 ElectraMidi::processSysex: applying extraction rule: byte=71, byteValue=0, extractedValue=0 to parameterNumber=90, type=nrpn resulting in parameterValue=0
21:39:54.762 ElectraMidi::processSysex: applying extraction rule: byte=70, byteValue=0, extractedValue=0 to parameterNumber=91, type=nrpn resulting in parameterValue=0
21:39:54.763 ElectraMidi::processSysex: applying extraction rule: byte=74, byteValue=1, extractedValue=1 to parameterNumber=93, type=nrpn resulting in parameterValue=1
21:39:54.764 ElectraMidi::processSysex: applying extraction rule: byte=75, byteValue=0, extractedValue=0 to parameterNumber=94, type=nrpn resulting in parameterValue=0
21:39:54.765 ElectraMidi::processSysex: applying extraction rule: byte=76, byteValue=0, extractedValue=0 to parameterNumber=95, type=nrpn resulting in parameterValue=0
21:39:54.765 ElectraMidi::processSysex: applying extraction rule: byte=79, byteValue=0, extractedValue=0 to parameterNumber=96, type=nrpn resulting in parameterValue=0
21:39:54.766 ElectraMidi::processSysex: applying extraction rule: byte=77, byteValue=0, extractedValue=0 to parameterNumber=97, type=nrpn resulting in parameterValue=0
21:39:54.767 ElectraMidi::processSysex: applying extraction rule: byte=78, byteValue=0, extractedValue=0 to parameterNumber=98, type=nrpn resulting in parameterValue=0
21:39:54.767 ElectraMidi::processSysex: applying extraction rule: byte=51, byteValue=1, extractedValue=1 to parameterNumber=119, type=nrpn resulting in parameterValue=1
21:39:54.768 ElectraMidi::processSysex: applying extraction rule: byte=62, byteValue=1, extractedValue=1 to parameterNumber=123, type=nrpn resulting in parameterValue=1
21:39:54.769 ElectraMidi::processSysex: applying extraction rule: byte=65, byteValue=6, extractedValue=6 to parameterNumber=124, type=nrpn resulting in parameterValue=6
21:39:54.770 ElectraMidi::processSysex: applying extraction rule: byte=52, byteValue=1, extractedValue=1 to parameterNumber=127, type=nrpn resulting in parameterValue=1
21:39:54.770 ElectraMidi::processSysex: applying extraction rule: byte=53, byteValue=1, extractedValue=1 to parameterNumber=135, type=nrpn resulting in parameterValue=1
21:39:54.771 ElectraMidi::processSysex: applying extraction rule: byte=91, byteValue=0, extractedValue=0 to parameterNumber=145, type=nrpn resulting in parameterValue=0
21:39:54.772 ElectraMidi::processSysex: applying extraction rule: byte=92, byteValue=0, extractedValue=0 to parameterNumber=146, type=nrpn resulting in parameterValue=0
21:39:54.773 ElectraMidi::processSysex: applying extraction rule: byte=93, byteValue=1, extractedValue=1 to parameterNumber=147, type=nrpn resulting in parameterValue=1
21:39:54.773 ElectraMidi::processSysex: applying extraction rule: byte=94, byteValue=0, extractedValue=0 to parameterNumber=148, type=nrpn resulting in parameterValue=0
21:39:54.774 ElectraMidi::processSysex: applying extraction rule: byte=95, byteValue=0, extractedValue=0 to parameterNumber=149, type=nrpn resulting in parameterValue=0
21:40:16.132 displayPage: page shown: page=0, controlSetId=1
21:40:18.576 displayPage: page shown: page=0, controlSetId=2
21:40:20.182 displayPage: page shown: page=0, controlSetId=1
21:40:21.918 sendMessage: port=0, channel=5, type=nrpn, parameterNumber=45, midiValue=1
Steps to reproduce:
- Load the E1 preset
- Set the MIDI channel accordingly
- Request the patch from the synth
- Try to use a control
Metadata
E1 version info:
- revision 2.40
- firmware v2.2
I’m using USB MIDI host.
