it worked fine when I tried it … otherwise I wouldn’t have posted here
the e1 firmware and toolchains can change, so its always possible that things become mis-aligned at times.
I’ve not been compiling the E1 code recently, as Ive been waiting for it to ‘settle down’ again. as it was going thru some pretty major changes, and didn’t want to have to keep updating my own source code to follow it.
The idea is to make the Midi Controller application (the one we all are using) just another application that runs on the base firmware foundation. When that point is reached, I will claim the base firmware to be mature enough for developing other apps. Many people are currently helping me to get things right, I think we are getting close to that point…
The Electra One mk1 firmware is open source and we keep it that way. That is what you have seen on the github. Electra One mk2 was introduced at the time of the global electronic components shortage. At that time, we had to change the main CPU on a very short notice to be able to keep the project alive. To do so, we used Renesas SSP libraries in the mk2 firmware sources (the base USB stack, SDRAM, etc). These have proprietary license that does not allow us to simple share it on github,
We are getting rid of these libraries replacing them with our own implementation. Kind of step by step when there is time for that. But as there was almost no interest the firmware sources, we spend more time on improving the Lua API that allows building quite complex presets without modifying the base firmware.
Thanks for the explanation. That makes sense about licensing.
I found sd-4.0.zip, the preset library, and the API docs. I looked at the Lua code for your generative sequencer and the Ableton Live script by JHH. Yes, you can do a lot with the existing API!
It might be convenient to have: 1) the API source, with or without function implementations; 2) the docs in original .md form; 3) the web editor source.
In the end I’m not sure about a purchase. I only have one unit that really needs the 6x6 dispatch mode. However, I spent some time investigating so here is my feedback. I hope it helps!
I would love to see this come back! I have an Electra One Mini for use with my own custom software Simularca and I would love to be able to completely customise how the control scheme works since my use case is quite distinct. It just arrived today so I’ll try first with Lua to see how far I get with that
I am currently traveling and often away from the internet. Hance the slower communication. The important info here is that all my efforts go now into preparing E1 firmware (mk1 / mk 2 / mini) for being opensource. it is one of the main priorities now as I see it as the most rational step for the project to progress further.
@martin - thank you for such a quick reply! I’ve been having fun with my Electra One Mini. I couldn’t see a video upload option here so I made a little YouTube short:
What would be amazing to have in future Lua API:
Custom controls (i.e. be able to replace the CC control with something completely custom, with custom signaling and display)
Some way of making a Lua action happen on a button press (not sure why by this seems difficult at the moment)
Larger fonts available (Ideally 4 font sizes)
Polygon rendering (e.g. draw a filled polygon)
Of course, if it was open source then I could add these things myself :). Also maybe get a bit more performance out of the device by coding things natively / using bitmaps instead of polygons, etc. In general I don’t really need it to work with anything other than my own software, and I’d like to have 100% control over how the device works, but I think there’d also be a happy in-between of adding extensions to the Lua API and using those in my own presets.
I haven’t yet been able to figure out how to assign the 4 custom buttons to functions in my own preset yet, but I see there are some notes in the forum about presets that have this working so I’ll look into these more.
Hi @martin is the latest source for Electra mk1 available? I found a repo on Github but not sure if it’s official and it seems very old. Please could you confirm if this is legit and the latest version?
I originally wanted to make some changes to them before making the repository public again. However, since the work on open-sourcing mk2 is keeping me busy and my time is limited I think it is only fair to make the mk1 sources accessible in the meantime.
Just a side note, in case anyone was wondering: the mk2 firmware cannot simply be released like this yet, as it contains parts of Renesas source code that prevent us from licensing the whole project under GPL/MIT. I am working on it.
Would it be possible to release it sooner incomplete or under a restricted license that could later change to an open source license? There is value in the source code as a form of documentation.
Great to hear that we might still be getting an open source implementation of the firmware sometime!
I did get a bit bored today and starting to develop my own firmware from scratch. It’s a bit painful, but after making my own secondary bootloader (which gets loaded by the main bootloader), I can now iterate on application firmware without having to do a physical reboot, which means that a coding agent is able to iterate by itself.
So far I’ve managed to get the display, buttons, capacitive touch and encoders to work
Other features that are in:
Remote screenshots (useful for development)
More system fonts
Tuning on the capacitive touch controls (I was having issues on stock firmware with touches being not detected or latching after release)
Debug console COM port
And aiming for:
Replace my Lua implementation with a native implementation
Skip MIDI and go for HID instead (since I’m writing the app on the computer side also)
Maybe upgrade to USB 2.0 (it seems to be running at 1.1 right now)
Generally, I was having issues with the Lua script implementation being glitchy and text being difficult to read, so I wanted something where I could both live debug the app and get more GUI features.
@martin - please let me know if you want me to stop going down this route for any reason.
It is all fine with me. I would only wish that any work like this were made publicly available to others. But that is just my personal wish.
I guess you had to figure out many things, and it must have been a bit cumbersome. I will mention a few things that might definitely make it easier:
I have already separated the Renesas proprietary (mostly HAL) code into a .a archive and a set of my own headers. Therefore, the mk2/mini source code will be available very soon.
The mk2 and mini PCBs are already prepared for installing a JTAG connector.
It uses the SWD I/O pins for programming and debugging. For any serious development, I would recommend fitting the FTSH-105-01-F-DV-P-TR 10-pin connector on the board and using a J-Link programmer/debugger. We use J-Link Plus, but for non-commercial purposes you can use the cheap EDU version. I am using the Cortex-Debug extension in VS Code, and it works perfectly.
Another option - only for flashing the firmware - is to use Renesas Flash Programmer (RFP) tool. It is available for Linux and Windows. Free - you need to register on Renesas website though. With RFP you will be able to place your bootloader at address 0x0, effectively replacing mine. Note, current address layout is 0x000000 for bootloader and 0x100000 for the main firmware.
I will share the schematics on the electra.one website when the firmware becomes public. However, so as not to keep you waiting, I have already enclosed the schematics here.
For fabrication/production, the complete circuitry is split into two independent schematics/boards.
As you already know, the important ICs are the Renesas S7G2 (MCU), Levetop LT7686 (video controller), and AT42QT2120 (touch controller). Potentiometer and button readings are multiplexed using an array of 4051 multiplexers.
I hope this helps. More info will be available soon.
Thanks for sharing so much info @Martin! I did have the J-Link EDU somewhere before but it’s missing now. I’m just coding with the top on hitching a ride on your bootloader, with my own bootloader running inside that, so I don’t need to use the J-Link (instead, I’m flashing it like an Arduino).
My progress is here:
I’ve run out of Claude credit for this week so it’s paused for now, but I’ll continue again next week. I could do with spending some time on the readme and to make some examples.
Also I want to rename the repo to reference the fact that this is more of an alternative stack (not the official fw), but i’ll wait until I’m coding again to do that.
in terms of that JTAG on the board - it looks like there was a connector there but it was desoldered. Is that correct? i.e. that’s the way it comes shipped (JTAG used for flashing then desoldered)?
