Expansion of controllable MIDI parameters by “push & turn”
Parameter 1: turn the encoder.
Parameter 2: push and turn the encoder
I like that. I had similar idea with the vertical faders, possibly with another click allowing to modify both values at the same time, yet keeping their relative difference.
Another idea is to set a range. Usually, a parameter such as cutoff has a certain range in which the parameter sounds great.
Parameter 1 / Start: Button A + turn the encoder
Parameter 1 / End: Button B + turn the encoder
Parameter 2 / Start: Button A + push & turn encoder
Parameter 2 / End: Button B + push & turn encoder
A control that requires two hands to operate is going to be a challenge for many users.
I obviously didn’t express myself clearly. This is only for setting the range on the device. It could also be done in the editor. For me, it’s important to be able to set a range.
Take the cutoff, for example. The default is 0 to 127, i.e. the entire range. But I want to limit this range to, say, 12 to 76, because that’s where the sweet spot of the cutoff lies.
