@Tomas Thanks! All is working well with ADSR
@markus.schloesser Martin is busy with assembling the new units. He will get back and reply tomorrow.
Markus, I am unable to replicate it. I added a new ADSR on to a page, enabled Attack MIDI learn, and sent a SysEx message to the appropriate Electra port. The SysEx Data field of the attack value got filled in correctly.
But when I read your message carefully I noticed you say you “twist the knob on Electra”. Do you twist knob of an existing fader that controls attack? Electra does not listen to its own messages. Can you elaborate a little bit more what you are trying to achieve. Thanks!
@martin yes, instead of having to create the sysex for the mks80 again by hand, I thought I just use the existing FROM the Electra. Shouldn’t be a problem? the website listens to midi coming IN from stuff, why not from the Elektra?
Also I am using (my) the existing mks80 template in the editor and added a new page and pulled the adsr env in.
@martin any news w re to my issue?
As that siuation is a bit rare - I suggest a workaround:
- Make sure MIDI thru is disabled on the MIDI IO 1
- Connect MIDI IO 1 OUT to MIDI IO 1 IN with a cable
- Drag the sysex ADSR to the page (page 3 in the case of the MKS-80 preset)
- Actieve the Midi learn on the attack value
- Twist the existing Attack fader.
I tried it, seems to work fine. if you need help, let me know.
