Firmware v5.1.0 for mk2/mini
Firmware v5.1.0 is now available at app.electra.one, on the Controller Settings page.
Besides several minor improvements and bug fixes, this release introduces a more significant change for Electra One Mini. The Mini now identifies itself over USB as Electra Mini instead of Electra Controller.
This change was necessary to allow @moss to reliably distinguish between the regular Electra One controllers (mk1/mk2) and the Mini.
For macOS users: If you want macOS to recognize the controller under its new USB name, disconnect the controller, open the Audio MIDI Setup app, and remove the existing “Electra Controller” entry, then connect it again.
Changes:
  • Changed mini so that it identifies itself as “Electra Mini” on USB
  • Use different set of fonts on each model, to better mach the resolution and screen size.
  • Add Lua function to hide the control set indicator.
  • Allow change of active value for custom controls
  • Add a new splash screen.
Fixes:
  • Fixed Custom control not repainting when any of its values changes.
  • Fixed issues with proportional controls steppings.
  • Fixed Lua value:toMidi() and value:fromMidi() to clamp a number outside the range instead of wrapping it.
  • Fixed randomly hidden MENU and Context buttons on Mini.
  • Fixed moving a control losing its detail state and its linked controls.
@martin Could this be a per page setting rather than a preset global?
