I’ve put the contents of the zip file from Github into the directory as instructed.
/Users//Music/Ableton/User Library/Remote Scripts/ElectraOne
Then then next step is to Add E1 as a Control Surface in Live - but it doesn’t show up. I’ve rebooted and reinstalled it but no change - it’s not there
As per your directions… unless I’m reading it incorrectly "Create a new directory ElectraOne into your local Ableton MIDI Live Scripts folder: that is, create /Users/username/Music/Ableton/User Library/Remote Scripts/ElectraOne on MacOS**
May I ask for another clarification or direction? How do I upload Mixer.eproj to a preset slot? I am able to upload presets with the app easily enough but don’t know how to upload this.
Thanks so much for sharing all the work you do with the E1
What in actual fuck… now I can’t get the dang thing to show up after playing with the STEP 5 part of the installation - yeah I jumped past Step 4 because I cannot seem to find the info on installing the mixer part…
the mixer must be loaded to the controller in order to have the ableton remote script working. There are three ways to do that:
Use the preset that @jhh maintains in the preset library. To do so, open the preset selection on the hardware controller, select bank 6, and tap on the first preset slot (top-left). An empty preset will show up. Then, search the Ableton Mixer preset in the Preset Library. When found, click on Send to Electra:
Go to the Controller page in the web app, there select the Preset Slots tab. Scroll down to Bank #6 and click on the slot 1. That will select the Bank 6 preset slot 1. Then, you can use the right side of the screen to find the Ableton Mixer preset and click “Upload to slot” button.
You can import the mixer.eproj to your own presets, ie. not using the preset mentioned in 1. and 2. You can do this by going to My Presets, and clicking on the Import Project button:
and happy to see MOTU Timepiece in action. I am still using one of them too. I have a preset that can be used to configure routes. I will share it on the web, I thought nobody uses these any more
