I’m still working on the Mirage SoundProcess project and I’m encountering something weird when tackling the Patch Transpose parameter / control. The raw values are 0 to 60. The control goes from +12 to -48 half tones. I got that working but I cannot seem to switch directions… I would like to go from the lowest possible value (-48 to 0 to +12) to the highest… Left to right. Just switching the Min / Max values from now 0 and 60 to 60 and 0 doesn’t work for some reason.
That doesn’t work as you found out. That may change in the future, but for now set the range 0 to 120 and do the math in a formatter function to display the correct value. MIDI is always 0->some positive value, so the synth should handle it
