Hi lovely team
Suddenly my Electra one doesnt work as it should
I dont know if its cubase
All this time everything worked fine
I m using an Esi m8u ex
So when i m opening a midi track
I m using as midi input the electra one ctrl
And midi out the midi channel that is connected to the midi input of my synth the editor doesnt work
When i m doing it with midi out from Electra one everything is working fine with my synth
So its like the midi input is not working at all with the above example
A small recap
Midi in electra one ctrl
Midi out esi midi port 8 to my synth input
why do you use e1 's CTRL port as an input? And have you used that before too? The CTRL is meant for controlling electra controller itself (web editor is using it or you can use it to control E1 with an external controller). Can you try using Port 1 or Port 2 instead of CTRL?
