Misi
May 8, 2021, 3:37pm
1
Hi all,
I am not sure if it an idea or more of a problem.
I would like to merge MIDI messages with MIDIOX but it seems that E1 can be used only by one application at the same time. So if use certain E1 ports, I cannot assign them in MIDI OX and vice versa.
Is it something that can be addressed or is there a solution?
Thank you!
Mihaly
this is a windows issue/limitation ( * ) there has been some discussion of this here
I am trying to see if there is anybody who would be able to give an advice on this.
Electra is a MIDI class compliant device. It means no drivers needed to get it working when you connect it to a computer. This works perfectly on Mac OS X and Linux. It also works on Windows but there is a big drawback. The Windows MIDI driver allows only one application to access/use the device at the time. So if you want to use the editor and the DAW in the same time you will fail. This problem was reported lo…
( * ) macos, linux allow midi devices to be used by multiple applications at once.
Misi
May 8, 2021, 8:56pm
3
Thank you, Technobear! (lovely name)
