Mini remote script for abelton
Hi All
I received my mini today, has one had any luck with a script for ableton live ? I have seen there is one for the Mk2, but nothing on the mini. Any help would be appreciated with how to get started creating one.
Thanks
T
Hi, the remote script works for the Mini, it’s just that I haven’t been able yet to create dedicated presets for the Mini (necessary because of its smaller screen). @Martin should release an update to the Mini firmware soon that contains the necessary fixes. I have some ideas for a mixer preset for the Mini (but it needs support for additional controls in the firmware); once finished I will release it as premium content.
Hi, thanks for the reply, i spent the night trying to get it to work but failed miserably. i downloaded the package and installed it but the script is not creating the files in the location it states it would
Can you mail me (info@xot.nl) with some details (os version and location you expected the files to appear in)
There was a bug in the installer that is now fixed. The E1 Mini is supported, but dedicated preset designs are still missing. There also isn’t a mixer preset yet. However, the E1 Mini can already be used to effectively control the currently selected device as the default configuration generates presets with the most common parameters added first (so called DEVICEDICT order, the way all remote script for other controllers automatically order the parameters).
thanks for all your help, everything is working as it should
