Patch request on TX81Z. Anyone have it working?
I have the Electra tweaking the TX81Z no problem but I can’t seem to get patch request going. Any tips? I have midi cables going in and out of the TX…
Thanks
Thanks
Let’s start with the basics’
Hi. Thanks.
The preset is the main TX81Z preset in the preset area I downloaded. Its supposed to have patch request enabled within the preset.
I am on the correct midi channel and I am also seeing the midi in and midi out flashing on the Electra. I have midi cables going in and out of the TX81Z into the Electra midi 1 out and midi 1 in/
Yes the midi port blinks quickly when I press patch request.
Cheers
Hi , that seems all right, so I downloaded the preset and gave it a look. I can’t find nothing however that indicates patch requesting is foreseen: there is no json in the patch editor for that purpose nor lua code that would do the trick. Both are empty.
I read in the description as well the builder of the set up meant to provide this, so maybe he hasn’t done it yet, or maybe he published the wrong preset.
You will have to ask him.
Hi
Thanks for looking into that for me. That makes sense with there being no patch request. I’ll message the guy that designed to preset to see if he has any ideas on adding patch request to the preset.
The TX81Z supports patch requests. I created a DX11 editor based on it as well.
At some point the webapp got updated and the patch requests broke.
I you have a working version, you might publish it as a new preset
