Here is my new preset for the Pioneer AS1.
This preset is based on Pedro’s AS1 preset and includes bidirectional communication and it parses the currently loaded patch.
The Pioneer AS-1 is a great synth.
Its simple and is like a Prophet 6 voice but with more balls.
I own 2 units and a Prophet 6.
The plan at some point is to make a template to perform with both at the same time.
To use the template set your device to midi channel 3 and enable midicontrol and the correct sysex cable.
Besides that LUA code needs to be added so the correct display the correct FX parameters.
And I see @NewIgnis has this code for the Prophet 6.
That is just great
@NewIgnis Once the patch parsing is completed I can add it to the Prophet 6 template as well.
It should be almost the same. except the FX.
For what I understand you can send the Prophet 6 erdit buffer to the AS-1.
The following parameters are not correctly parsed
MOD DESt OSC2 AMNT
SEQUENCER LENGHT
SLD DEST OSC2 FREQ
SLD DEST LPF Cut
SLD DEST HPF Cut
SLD DEST LFO AMOUNT
SLD FX1 AMNT
SLD FX2 AMNT
The following parameters are missing
KEYMODE
AFTERTOUCH AMOUNT
AFTERTOUCH DEST OSC1 FREQ
AFTERTOUCH DEST OSC2 FREQ
AFTERTOUCH DEST LPF CUT
AFTERTOUCH DEST HPF CUT
AFTERTOUCH DEST VCA AMNT
AFTERTOUCH DEST LFO AMNT
Once completed lets looks @martin his performance page in the new firmware.
open ideas:
performance page
support for multiple units
sub templates ( vco, vcf, vca envelope, fx )
Morphing would be awesome. Load a patch. Jam on a beat… morph back and forth to the original.
The template is now fully implemented except the sequencer and the quick patch select. Not sure If I will ever need them.
Thanks @NewIgnis I was able to use your LUA code for the fx parameter names.
Thank you for creating this editor. I appreciate it. Unfortunately I couldn’t get the patch parsing to work on my end. Possibly user error. Could you outline the steps necessary to make it work?
@eusti if it does not work please share the sysex.
Connect to the editor and use the midi console. select there the electra one and press the “patch fetch” button.
