Turned on my electra today. All presets wiped. Went into app.electra.one to try and reload one. Whenever I try to send a preset I get a Preset Transfer Failed, Please Retry message. Have reuploaded the firmware and get the same message. Running 1.4
Text from the console app
195731 processElectraSysex: sysex received: command=1, parameter=0
195732 Read file failed: ctrlv2/p000.epr
195736 ElectraApp::reset: preset memory deallocated
195736 free RAM: adj_free=191504, heap=3360, state=0
195736 Preset::load: file: filename=ctrlv2/p000.epr
195737 Preset::load: cannot open preset file: ctrlv2/p000.epr
195737 ElectraApp::displayPage: pageId=0
195737 free RAM: adj_free=191504, heap=3360, state=0
195737 readMidi: CTRL message: port=2, channel=0, type=240, data1=5, data2=0
If I use the reset option on the Console App. I get the text below
4890 internal storage: Mounted
4891 CapSense::init: waiting for touch to initialize
4915 capacitive sensing: Initialized
4925 screen touch: Initialized
4925 MIDI IO: Initialized
4925 USB MIDI: Initialized
4925 Powering up USB host devices
4955 USB Host: Initialized
4956 ADC: Initialized
4956 kernel task manager: started
4957 free RAM: adj_free=191504, heap=3360, state=0
4957 Setup::load: file: filename=ctrlv2/setup.cfg
4957 Setup::load: cannot open setup file: ctrlv2/setup.cfg
4957 setting up the forwarding
4957 ElectraApp::displayPage: pageId=0
4957 Setup::serialize: cannot open setup file for writing
4962 file to be loaded: ctrlv2/p006.epr
4962 Preset::load: file: filename=ctrlv2/p006.epr
4962 Preset::load: cannot open preset file: ctrlv2/p006.epr
4962 ElectraApp::displayPage: pageId=0
4962 setup: preset load failed: name=
4962 free RAM: adj_free=191504, heap=3360, state=0
4962 processGeneralSysex: manufacturer 0
4962 getting a device: port=0, channel=0
4962 handleIncomingMidiMessafe: Sysex message
4962 handleIncomingSysex: SysEx received: device=0, data=[ “F0”, “F7” ]
4963 readMidi: MIDI USB Dev received: port=0, channel=0, type=240, data1=2, data2=0
4963 xxxxxi: port: 0
4999 processElectraSysex: sysex received: command=2, parameter=127
4999 processElectraSysex: electraInfo sysex sent to the host
4999 readMidi: CTRL message: port=2, channel=0, type=240, data1=7, data2=0
5000 processElectraSysex: sysex received: command=2, parameter=2
5000 Setup::serialize: cannot open setup file for writing
5000 sendSysexFile: the file does not exists: filename=ctrlv2/setup.cfg
5000 processElectraSysex: config sysex sent to the host
5000 readMidi: CTRL message: port=2, channel=0, type=240, data1=7, data2=0
5001 processElectraSysex: sysex received: command=2, parameter=0
5001 sendSysexFile: the file does not exists: filename=ctrlv2/p006.epr
5001 processElectraSysex: preset sysex sent to the host
5001 readMidi: CTRL message: port=2, channel=0, type=240, data1=7, data2=0
