"Radio Button" pad group behavior: how to force visual ON state?
Hi all!
I’ve been polishing my E1 MkII presets for Kinotone Ghosts and Ribbons.
In both presets I used groups of pads that are calling up different modes on these pedals, and modes can be active one at a time. I didn;t want to use the list, and tried to make a group of pads that will be mutually exclusive in their toggle behavior.
It kinda worked, whenever I toggle on one pad in such group they do indeed toggle other members of the group OFF.
However, there’s a minor nuisance: if I tap again the pad that is ON, it visually toggles OFF. It does not send anything wrong in terms of midi commands, and the logic stays intact, but I’d love to find a way to prevent that bright side strip from going OFF if I tap or otherwise activeate the pad that is already ON.
Any ideas? Here’s the abstract of the Toggle Group code I use.
local padGroupTouch = {4, 9, 10, 11, 12, 13, 14}
function radioTouchGroup(valueObject, value)
    local currentControl = valueObject:getControl()
    if currentControl == nil then return end
    local myId = currentControl:getId()
    -- This catches the touch event exactly when a pad transitions to ON (value is NOT 0)
    if value ~= 0 then
        -- Loop through group to turn off ALL OTHER pads
        for _, padId in ipairs(padGroupTouch) do
            if padId ~= myId then
                local otherControl = controls.get(padId)
                if otherControl ~= nil then
                    local otherMsg = otherControl:getValue():getMessage()
                    if otherMsg ~= nil then
                        otherMsg:setValue(0)
        -- Send the pad's native Device MIDI message
        valueObject:sendMessage()
    -- Handles locking the active pad state when tapped again
    else
        local anotherIsOn = false
                    if otherMsg ~= nil and otherMsg:getValue() ~= 0 then
                        anotherIsOn = true
        if not anotherIsOn then
            local myMsg = currentControl:getValue():getMessage()
            if myMsg ~= nil then
                local maxVal = myMsg:getMax()
                -- Delay execution by 20ms to allow the hardware UI rendering frame to clear
                timer.add(20, 1, function()
                    -- Silently restore the message value stack
                    myMsg:setValue(maxVal)
                    -- Snap the display value and force a clean visual update
                    valueObject:setValue(maxVal)
                    currentControl:redraw()
                end)
