Brand new Electra One MK II owner here (first evening playing). I primarily bought the unit to use with the DrivenByMoss Bitwig extension.
I have:
- Electra One Mk II v3.0, firmware 3.6.0 (pre-installed)
- DrivenByMoss Bitwig extension and E1 .eproj file v23.2.1
The bitwig preset is working 100% OK if I reset the E1 unit, and use the faders on the first preset page (Mixer). can see the E1 knobs are sending on MIDI channel 16, CC 10, value ranges 1-2 (turning CW), and 125-127 (CCW)
BUT, after changing page on the preset (e.g., to “device”), any knobs that I moved on the first page no longer transmit the same value ranges back to Bitwig . they now transmits 102-103 (CW) and 97-98 (CCW). The translated values are now all wrong and the bitwig controls do not respond.
Knobs that I had not yet touched on the first page work OK after the first page change. But as soon as I change page, those knobs also no longer send the original value ranges either.
Once this happens, the only way I have found so far to restore operation is to reset the E1 device.
I had a look in the DrivenByMoss eproj file … it seems all the faders are mapped as relcc twoscompliment relative controls:
"values": [
"id": "value",
"message": {
"type": "relcc",
"deviceId": 16,
"parameterNumber": 12,
"min": 0,
"max": 127,
"relativeMode": "twosComplement",
"accelerated": true
"min": 0,
"max": 100
Not sure if this is related, but I also cannot get the new DrivenByMoss multi-touch combinations to work either.
I thought I would post something here first in case this indicates a wider issue with the 3.6.0 firmware rather than the DrivenByMoss preset or script. I don’t have access to a previous E1 firmware to see if that is the root cause.
The E1 hardware looks just great - love the screen and feel of the controllers!
