I’m working on a preset where I want to select for instance the LFO1 WAVEFORM, when I use the text option everything displayed is white despite the control being colored (red in this case) and I can see why that is as it is easier to read. As a visual person I would like to have bitmaps for the options TRIANGLE, DWN SAW and SQUARE. When I use them they are now in red. Nice! But the other option is “None” which causes a weird mix of colors then… I would like for that to change.
Interesting is that in the web editor the text is represented in the color of the control.
Thanks!
D.
PS: I found a workaround for this case: I just did a horizontal line for “None”.
