Hi @martin,
Hope you are enjoying a well deserved rest from assembling
Would it not be a good idea to have a preset, when it is loaded or at boot-up time, send out it’s load request(s) (Request Patch) automatically? Currently it is a manual operation, and it requires the knowledge that the console does not reflect the state of the connected devices.
Cheers,
Joris
I had it that way in order versions - I mean that the Patch requests were sent out after the preset was loaded. I removed it and I cannot remember why. It is fairly easy to add. Also, the new Lua API has the patch.requestAll () call. If this is placed in the setup part, it will run the request right after the preset is loaded.
I’ll test it out, thanks so much for this!
