In the sysex control message editor you can select each block and drag and drop each byte to rearrange them if you need to adjust the order. That feature is really helpful and quite nice to use. That feature isn’t available when using the sysex request editor. You can’t rearrange the blocks in the gui. I find myself editing the json to remedy any errors I’ve made but it would be cool to just drag and drop the blocks like in the sysex control message editor.
yes, I agree. It is something that needs to be added there. The only way to rearrange “bytes” now is to switch to the JSON editor and edit the source.
