I would love to be able to turn of the feature to select one of three rows by touch input.
reason:
I use the Electra one as a performance controller. it is not about programming a synth but as modulating them during a jam or a performance. When doing so, a lot of stuff is done more or less blind. You reach your hand to a button and twist it while doing other stuff with the other hand. that is quite often doing 2 things per hand at a time.
Sometimes but quite regularly I reach to the Electra one but nothing happens (or better, something that was not expected changes). The reason is, that I somehow touch the screen and select the bottom row, and then turn a different value then I indented.
It would be great if there were some config part (afaik can you send a JSON to the Device to manage midi routing etc.), where I could turn that feature of. I could still change the row with the 3 buttons.
Should not effect anyone, if it is a config setting that is disabled by default.
Thanks, Jens
