I’m just about to pre-order a MK3 and wanted to check a couple of assumptions I’d made.
In my studio I have 7 hardware synths, some with USB and some with DIN MIDI, and 7 hardware reverb/delay units, all with DIN MIDI. They are all connected to a 16-in 16-out USB MIDI interface. I run Cubase and now that Windows MIDI is multi-client, I assume that when I connect the Electra.One via USB it will see each individual MIDI or USB port and I can setup the presets to always address those rspective ports, correct? And it will work seamlessly whilst Cubase is also addressing those ports.
My main use case would be wanting to dive into some patch editing to adjust something on one of the synth or FX units, whilst I am running a session in Cubase. For me to get value out of the Electra One and for it to not be one of those dust-gathering purchases, it needs to be 30 seconds or so and a couple of clicks to get to the preset for whatever unit I want (after the initial setup of the unit when it arrives). So, for example, when turning the Electra One unit on, does it take a long time for it to scan and find the ports, before you can load the preset ? In Cubase for example, if you switch on a USB synth whilst a project is open, it’s maybe 5 seconds to recognise it, which of course is not a problem.
Thanks for checking before you order, because one of your assumptions needs correcting.
The Electra One will not see your interface’s ports. Over USB the controller appears to the computer as a MIDI device with its own ports (Port 1, Port 2 and CTRL), much like a keyboard controller would. It cannot look through the PC to the devices connected there, and Windows multiclient MIDI does not change that. Multiclient lets several programs share a port, but the Electra is not a program on your PC. Some kind of routing on the computer would be needed (eg in DAW)
If a preset already exists for a particular MIDI device, setting things up can be quick and easy. If there is no preset, creating one requires time, knowledge, and some effort (things can get complex and difficult). I suggest checking the library of existing presets first.
