V4.0 testing [was V3.7]
There are other ways to trigger this behavior. All steps expect the plugin to be installed and the plugin to have loaded its (shipped) map and displaying it on the E1.
Using u-he Diva
  1. Go to Module “Osc” or “Filter”
  2. Change the “Model” type parameter (OSC: Knob 1; Filter: Knob 3) using the E1
  3. Notice that for every model change, there’s a noticable stutter happening
  4. Now use your mouse’s scroll wheel/scroll gesture on the touchpad to change that parameter in Diva’s UI instead. When I do that through the params range (fully up and fully down) once, it’s usually fine but when I do this like 20 times up and down, it takes multiple seconds to catch up.
Using Reason
You can download Reason via torrent (yes, it’s official) from here: https://help.reasonstudios.com/hc/en-us/articles/360002216653-Download-using-BitTorrent
You should be able to run it in demo mode without an account, locally.
Load the VST3 plugin, then:
  1. Add an instance of Thor
  2. Go to Thor (Module) and select “Osc 1” or “Filter 1”
  3. Change the Type parameter (Knob 1) a bit, it’ll quickly start to become too stuttery to make meaningful adjustments
I want to acknowledge that this has improved with the upcoming firmware (that’s great, thanks for all the improvements), but it also doesn’t feel fluent. Can you find any calls from my script that are causing these slowdowns?
