@martin for all those not as familiar with lua / JASON it would be a great feature to have the possibility to insert bytes in the visual editor on any position, not only at the end! And also the option to change every byte direcly from constant to value / lua function etc. using the same pulldown menue like in the ADD function! It would it make so much easier to adapt things on presets you already have programed (like inserting a linked parameter or a function afterwards in all parameters…
Related topics
| Topic | Replies | Views | Activity | |
| Web editor to switch between GUI and JSON data or only JSON for 1 parameter | 1 | 229 | October 7, 2021 | |
| LUA frustration | 18 | 501 | November 8, 2021 | |
| Preset file version 2 description | 27 | 1058 | November 8, 2020 | |
| [SOLVED] Lua formatter and lua function missing in Editor | 4 | 321 | August 5, 2021 | |
| Electra App update - Basic SysEx editor / Electra Log viewer / Device rates | 7 | 437 | December 14, 2021 |
