Has anyone tried to create a mapping for a VST loaded in Ableton Live? I wonder how people use predefined mapping from E1 to control VSTs loaded in Ableton. In Ableton Live, you need to ‘expose’ the VST parameters to ableton live and then MIDI-map those parameters. But once you load that VST new (or copy the VST to anther track), you need to repeat the MIDI-mapping. Maybe there is a easier way to re-use the mapping?
I want to get an E1 for controlling plugings (like Aalto). Any advice would be very appreciated!
I have not an Easier way to do that , but to get rid off the problem of midi mapping each live set for a same vst plugin :
yes, with ClyphX.
With biding scripts, and Controls scripts.
Not with that remote script, but yes with another one (for another controller).
The only thing to remember is that previously saved projects won’t have the (new) mappings saved
Is this really working? When I “save as default configuration” in Live 11 the parameters stay exposed, but the MIDI mappings are lost whenever I load a new instance of the device. Or did I misunderstand you?
“save as default” only saves the exposed parts, which is the only thing you need when working with a remote script (and not manual mapping).
If you also want manual mapping, you need to create it and save it as part of a template Project and then always start from there iirc (!).
That’s why I love remote scripts, less hassle
