I have a set of lists transmitting CC. Values are different, but none include zero. Default is 64. When Selecting “Send Current” It sends those values with all 0!
It s not easy to understand what you are doing without an example, but check if the values transmitted aren’t the positions in the list (first position =0, second =1, etc) rather than the actual value you gave to that entry in the list.
How to reproduce:
- Create a new project.
- Create a list control.
- In the list items, set the following values:
10 - ten
20 - twenty
- Set a default of 10 in the control.
- Send to electra.
- Monitor the CC output.
- Move the corresponding pot to the created list and see the midi values transmitted are 10 and 20 indeed.
- From the patch save screen, press “SEND CURRENT”.
- See that the CC Value sent is actually the one set on screen. This is ok!
- Send again the template to electra without touching the list pot.
- See that the CC Value sent for our list control is 0! This is wrong!
- Change to another preset, and then, load our preset again.
Yep, there’s definitely something not going well. The ‘send current’ option isn’t working correctly just after a preset is called. it looks as if the parameter map is not set correctly for all controls when calling a preset the first time.
