Ableton Live remote script updated to support Live 12.4.3
The Ableton Live remote script has been updated to support Live 12.4.3. See XOT Item : E1 for Live
First time trying this. Setting it up was a breeze. It is going to be so useful. Thank you! I noticed some midi mappings are off (specifically, in the Audio Effects: Amp). Ableton 12.4.3.
Strange. Can you explain how they are ‘off’? Amp seems to be mapped correctly on my side.
For example: Bass Roundup.adv. It shows as expected on the E1. But turning the control labeled Gain on the E1 moves the Treble control in Bass Roundup. Turning the Treble control moves Volume, etc.
I haven’t tried all categories, but so far Amp is the only one that doesn’t seem to map correctly.
I’m honestly flabbergasted. I just loaded Bass Roundup, and it works absolutely fine for me. To try to debug this, can you tell me how exactly you installed the remote script? And did you make any changes to config.py?
Followed these instructions As pushing a peeled tag, i.e. Pushing. I believe I followed every step. I’m on Windows 11.
Have not touched config.py
Very strange. Like I said, the other devices I have tried work fine. I was just surprised that the first one I tested was off.
Here is the Ableton folder
No clue yet… what is the contents of the ./predefined/mkI-II folder?
Is that the issue. Those Amp device presets aren’t in this build. I downloaded the free version.
Thanks. That looks as it should be. And you are using a mkII (not the Mini)?
That should not be the issue. In that case the script generates a preset on the fly, and on my side that works fine. On your side, not apparently
MkII. Latest official firmware. Want to move this convo offline? If so, DM me.
Can you send me the Log file (~\AppData\Roaming\Ableton\Live <version>\Preferences\Log.txt in a direct message (where ~ is your home folder)?
