Is it possible to add a “Logging/Debugging” on/off option to the controller screen?
If I try sending the MIDI string as a copy/paste from the documentation to the MIDI console, it is an invalid string with the hex notation. Adding quotes - still invalid. Removing the 0x prefixes - still invalid. It looks like the MIDI console needs decimal numbers only??
yeah, I know I am going to update all the hex numbers on the docs. I am personally used to 0x notation, but midi console uses the sendmidi format. ie. decimal numbers are just plain numbers and hex has the “h” suffix. (0Ah, 10h, 7fh, …)
In general this seems to work, except when I try to send numbers that do not contain letters.
so – F0h 0Ah 3Bh all work. When I put 60h in the array I get an error message saying something about invalid something near 60h
I had to change it to a regular decimal (96) for it to work properly. This was inside an array assignment loop inside some LUA code. myMsg = {10, 0, 0Ah, 60h, 3Bh}
the notation with “h” suffix works in the MIDI console. For Lua the native Lua syntax must be used. I do not convert the code in any way.
Thinking about that… I will probably add the 0x format to MIDI console. That way it will accept more ways of expressing the hex numbers.
And yeah, I was thinking about having a small built-in hex/dec/bin convertor or calculator in the web app. Switching to different app to convert numbers is irritating…
