Can I use Electra One with my Haken Continuum Fingerboard Full
Hi there,
I have a Haken Continuum Fingerboard Full, Max ver. 8.6.5. (20221216) and Haken Editor ver. 10.09.
I can`t load a newest version of HE 10.40.
Please let me know that ELECTRA ONE is compatible with my Haken?
Regards
Władysław Komendarek
Depends on the Haken. Anything it can transmit or receive via MIDI can be interchanged with the Electra One.
Hey Władysław,
You’d need to update your continuum to 10.40 to use that Electra One 10.40 Preset made by Richard. Any particular reason you can’t update your continuum towards 10.40?
Hello. Thank you very much for your answer.
You ask what is the reason that I can’t load s.o. 10.40
I have a haken continuum fingerboard model, which has over 90 keys. When loading S.O. 10.40, this message appears
your dsp hardware cannot load this version firmware, the final firmware for your hardwareis version 10.09 Please reply.
I am a concert artist, and pressing the edge of the key in the haken and pressing on the left side does not always change the preset to another and that is why I need something that will quickly change preset 1 to 8 or preset 4 to 11. Here is the problem. It is difficult for me to play the entire concert on one preset.
All the best
Understand, so you just want to change the user presets on your Electra one? I can send you my old preset for my continuum which should work with your fingerboard.I have sent you a private message.
Using Electra One to switch a preset seems a bit overkill. I am not a Haken user but maybe any cheaper controller that sends program changes would do the job?
I have a thick half-size 6x presently at 10.09, will update it to 10.40 if it will work in my system, which identifies itself as 46L6x. Dylan at HakenA confirms the 10.40 firmware will work on my fingerboard. Will the 10.40 Electra preset communicate correctly with my Continuum?
