The Electra One Mini does not seem to be triggering USB C power supplies properly. It does not power up when the USB B is plugged in via USB C directly to a
- Macbook Pro
- Macbook Pro power brick
- Two different Anker power banks
It does power up when the other end of the USB B is plugged into:
- The same Anker power banks via their USB A port (with the included USB C to A adapter)
- A USB hub either directly with USB C or USB A (with the included USB C to A adapter).
- This hub provides power when plugged directly into the USB C port of the Macbook Pro (or any of the other USB C options in the first list which do not power the device directly).
- Note that this hub has an extra port for incoming USB C power which I did not need to use.
- A low end USB A power adapter
Hoping this can be fixed with firmware. Please let me know if you you need more information.
it’s a failure mode for me to have to find a USB Hub to connect and power the Mini with my Macbook. Pretty handy to be able to use any USB C power supply directly.
