Changing preset via program change not working anymore after 4.0 update
Hi, I just updated my MKII to the 4.0 Firmware and when I try to select a preset sending a Program Change message to to the Electra CTRL Port no preset switching happens. This was working before with the 3.6.1 firmware. Is there some setting I have to change to make this work?
It is fixed in the upcoming release v4.0.2. I noticed that when using E1 by myself. The work on the v4.0.2 has been completed earlier today. I will make it available tomorrow.
Actually, I was just coming back to the forum to write that it works, the problem was that the Program Change message apparently now has to be sent to the Electra Port 1 port while previously it had to be sent to the Electra CTRL port. I’ve changed the port in the MIDI Translator Pro Routing configuration and now it works.
fixed in 4.1.0
