apologies if this has been raised in another topic somewhere (didn’t spot it)
I’ve a couple of related feature requests.
a) move routing to preset
so I move my E1 around my studio connecting it to different devices, and this entails the routing is configured differently in different scenarios.
so I actually quite like to say, this preset uses this routing, and another a different routing scheme.
(perhaps if this is not a common requirement, a preset could ‘override’ the current routing config)
b) more routing options, in particular cross-routing.
e.g. route midi din 1 IN to midi din 2 OUT
perhaps even restrict which midi messages or midi channels are routed.
this actually comes from a bit of a confusion Im having at the moment…
so what Im doing (today) is trying to insert the E1 into an existing midi setup
e.g.
Octatrack <-> Midi Router <-> (lots of midi devices)
to:
Octatrack <-> Electra One <-> Midi Router <-> (lots of midi devices)
so… what I did was connect :
Octatrack in/out into midi din 1 out/in
Midi Router in/out into midi din 2 out/in
k, this works… for step 1…
the octatrack has bi-directional communication, so I can update values on either E1 or Octatrack and it works.
it feels logical…
BUT the issue is… I get no communication from the Octatrack to the Midi Router
since this requires DIN 1 IN -> DIN 2 OUT
e.g. if I turn on midi clock … nada
k, so what if I do a cross-over…
Octatrack in/out into midi din 2 out/ midi din 1 in
Midi Router in/out into midi din 1 out/ midi din 2 in
k, this works for the router config, since now
octatrack data comes into midi din in 1, and e1 chucks it back out midi din out 1, connected to midi router - yay !
BUT now there is the opposite issue
the controls of a preset are attached to a particular midi port
e.g. octatrack levels is assigned to PORT 1 / Channel 1
so now I can send values from E1 to Octatrack (on DIN1)
BUT it cannot get values back, since these are coming in on DIN 2 !
so it appears that placing the E1 as an ‘inline replacement’ is actually not possible.
which is a shame, as in a complex midi setup like mine, this is really the easist way to place it
thoughts? am i missing something?
as far as I can tell the only solution is for me to put in place a smart midi hub, which can do this routing for me… ( I have a midihub and a mioXM so thats not an issue, just more configuration)
