I’ve been doing random playing around with various presets and my E-One hardware has junk presets in various places, other presets are assigned to a knob in a different bank, etc.
Since all my work is stored on the computer is there a way I can completely clean out the hardware and then download only what I want in the locations I want?
Ummm, was that actually in the manual somewhere? I did a forum search, but didn’t find anything and the manual only talked about using the button on the back panel.
Hi, what was happening that made you to reset the unit? Using of the factory reset should be quite exceptional. Maybe, I am missing something I could fix.
I’ve attached the log. I was building out a Hydra Synth patch. The unit just froze then it just won’t load past the loading screen when I unplugged it and plugged it back in. I then tried many things to get it to work. The clear unit seemed to fix everything. I was even trying to reload the firmware to see if that worked but it still just was stuck. It kept saying un connected too. The bottom of the log said “no memory” the patch was simple with only 17 parameters.
I want to say that I appreciate the quick response and seeing what the community is sharing in these forums made me realize that this product and you as makers being responsive made me feel warm at heart know ing the care that you put into your products. That is always key for me when choosing to buy equipment.
