Accelerated pot reading. Pot reading is now based on the velocity of turning. This makes it possible to smoothly reach all values of 14-bit controls.
Improved USB host communication. A fix based on issues with Arturia Keystep. Thanks to @Kai01W for reporting
Improved message forwarding between interfaces (MIDI IO / USB Host / USB device). Supports Sysex messages up to 512 bytes now.
Added a possibility to switch LCD off with a long press of right-bottom button. Hold the button for 3 seconds. The LCD can be switched on by pressing the same button again. Note, when LCD is switched off, Electra still handles all MIDI traffic. Mentioned by @ColdSteel
Hi, I know know where the problem is. The LCD backlight affects touch sensing functionality of the knobs and the knobs rely on the touch in order to work. it might happen that when the LCD backlight is switched off and later switched on, sensitivity of the knobs is affected. I will make sure that re-calibration of the touch sensor is run after the LCD is switched on. it should do the trick. hmm, I got too technical here I guess anyways, I will provide a fix in future release to make it more reliable.
