and it looks like I made some sort of streaming with a chat. I am not good in those things
The preset shows what the latest v3.5.4 on mk2 can do. Besides the sequencer itself, MKS-50 preset is used to tweak the sound while the sequencer preset is running on the background.
I am still working on the preset. It will be shared with the community very soon.
It is a Launchpad mini. It just replicates the grid on the screen. The preset can run without it. It just feels more convenient to use physical pads. The E1 preset re-programs the Launchpad to do the job.
I wanted to show that a preset can talk to devices connected to the USB host. It could be interesting for other stuff (eg @jhh’s ableton or @moss’es bitwig presets). With a few extra functions in Lua, it would be quite easy to create presets to integrate external controllers to E1.
Well , I have an old BCR2000 looking for being integrated to the E1 workflow
But it should be generic. In other words , the BCR2000 should take over, or whatever the page is showing on the E1, or a specific page that is temporarily dedicated to the BCR2000, just like you seem to do with the Launch Pad
The preset is public now. Please note there is still a lot do and improve. It is really meant to show that E1 presets can do quite complex tasks. I am still busy with improving timing, saving of pattern data, and thinking about how to support external controllers.
And again, you can use it only with v3.5.4 on mk2. Older versions and mk1 will run into problems. We will tackle this (version checking before sending presets to the controller in the editor) soon.
Very nice Preset - thanks a lot! and to be honest: it’s the first time that i realised, that we are not bound to the 6x8 Standard Matrix and that we can assign the Knobs as ever we want. That opens up a lot of possibilities
have something complex to throughfully test Lua in v3.5.4
show some more dynamic preset layout and think about how to tackle it in Lua
Regarding the latter I am still not convinced I found the most optimal way to manage the user interface, but it definitely brought some ideas. I can imagine that the firmware would build some of the objects/tables automatically. Just to save repetitive boilerplate work.
I played some time with the Seqencer and my Deluge and it is super fun! But i faced some issues. After a time, the Buttons seam to freeze, at least i can’t start/stop anymore or open the pages. Touchdisplay and the squencer are still working tough.
thanks for this preset it’s a very nice work!
started using it a couple of days ago with the launchpad mini mk3 correctly automapped
but there’s a weird behavior
I have to press the controller buttons twice to toggle and untoggle the steps…
also had a look to the code but still learning lua
so was not able to fix it
there’s a quick way to make it work with a single button press?
A bit late to the game but I discovered this preset while I was trying to come up with my own version of a Markovian sequencer using GPT 5.2 and failing miserably. This one almost behaves like ZOA, I mean my automata die too fast somehow, but I am even more puzzled with the UI which involves elements not available on the editor.
I think Martin has clearly demonstrated that essentially this is nearly as powerful as any other midi device/sequencer all together however I would appreciate some tutorials. Step by step.
I know this is massively time consuming but even going through loopop’s video https://www.youtube.com/watch?v=jY8WQfkgb9I today I was like “where are these UI elements and functionalities coming from”.
How did you desing the grid?
The Play/Stoped text in the bottom right?
The VOICES icons?
So confusing!
I have not seen the manual for a while but if you people have any advice let me know. I really want to explore some creative ideas I have but dont know where to start from given my limited time as well.
