Hi’, I’m running out of memory while creating the Korg 03R/W preset ![]()
In my opinion this issue is not limited to that preset but may be encountered for every preset that has an extensive effects section with lots of parameters that need special treatment. In many cases we need each parameter to use different ranges, names , colors depending depending on the type of preset it is used in. Try it out in the effects section of the preset, it makes working with the effect a 1000 times more comprehensive.
I 've made these effects settings work by using arrays per effect type and per attribute to control. In Korg’s case, there are 25 different effect types and I need to set the color scheme, names, min and max values for 7 controls.This implies a total of around 700 array members to keep in memory.
Up until the 20th effect type it all worked, but as of the 21st the E1 runs out of memory.
Can I work around it? Can I make the preset deal with memory more efficiently?
The preset where I use those arrays is to be found here. Electra One App
To give you an idea, the arrays I made are shown below. They are not difficult, but they are extensive and contain a lot of work (incorrect SysEx docs, who’d have guessed…). Do remark I did not make them as local variables out of fear of losing speed, would that improve things? The logic where there are used is concentrated in the function called “setFx1”. Second to last one in the lua code
Any suggestions on making memory usage more efficient?
fx1Control={123,124,125,126,129,130,131,128,122,127}
fx1Param ={160,161,162,163,164,165,166,159}
fxIndirectRef= {1,1,1,1,1,1,1,1,1,2,2,2,3,3,4,5,5,5,6,6,7,7,8,9,10,10,10,11,12,13,13,14,14,15,16,16,17,18,18,19,19,20,21,22,22,23,24}
fxColorRef= {1,1,2,3,1,1,2,2,1,1,1,1,1,1,1,1,1,4,3,3}
fxNames = {{"reverb time","pre delay","earl.refl.time","high damp","eq low","eq high",0,"dry:fx bal."},{"earl.refl.time","pre delay","eq low","eq high",0,0,0,"fx balance"},{"delay left","delay right","feedback","high damp","eq low","eq high",0,"fx balance"},{"delay L","feedback L","high damp L","delay R","feedback R","high damp R",0,"fx balance"},{"delay 1","delay 2","feedback","eq low","eq high",0,0,"fx balance"},{"delay time","mod speed","mod depth","mod waveform","eq low","eq high",0,"fx balance"},{"delay l","delay r","mod speed","mod depth","mod shape","eq low","eq high","mod speed"},{"delay l","delay r","mod speed","mod depth","fq split point",0,0,"mod speed"},{"mod depth","eq low","eq high",0,0,0,0,"fx balance"},{"delay","mod depth","mod speed","resonance","eq low","eq high",0,"mod speed"},{"blend","emphatic point","eq low","eq high",0,0,0,"fx balance"},{"density","hot spot","stereo width","delay time","eq low","eq high",0,"fx balance"},{"drive (edge)","hot spot","resonance","eq low","eq high","out level",0,"hot spot wah"},{"manual","mod speed","mod depth","feedback","waveform",0,0,"mod speed"},{"vibrato depth","acceleration","slow speed","fast speed",0,0,0,"speed"},{"waveform","mod shape","mod speed","lfo depth","eq low","eq high",0,"dry:fx bal."},{"freq low","eq low","freq mid","eq mid","width mid","freq high","eq high","freq mid"},{"ch. delay","ch.feedback","ch.mod speed","ch.mod depth","delay","feedback",0,"dry:fx bal."},{"delay","feedback","high damp","rev time","pre delay","high damp",0,"dry:fx bal."}}
ctrlMin={{0,0,0,0,-12,-12,0},{0,0,-12,-12,0,0,0},{0,0,-99,0,-12,-12,0},{0,-99,0,0,-99,0,0},{0,0,-99,-12,-12,0,0},{0,0,0,0,-12,-12,0},{0,0,1,0,-21,-12,-12},{0,0,1,0,0,0,0},{0,-12,-12,0,0,0,0},{0,0,1,-99,-12,-12,0},{-99,1,-12,-12,0,0,0},{1,1,0, 1,-12,-12,0},{1,0,0,-12,-12,0,0},{0,0,0,-99,0,0,0},{0,1,1,1,0,0,0},{0, -99, 0,0,-12,-12,0},{0, -12, 0,-12,0,0,-12},{0, -99, 1, 0,0,-99, 0},{0, -99, 0,0,0,0,-12}}
ctrlMax={{99,200,99,99,12,12,99},{70,200,12,12,200,200,200},{500,500,99,99,12,12,200},{500,99,99,500,99,99,200},{500,500,99, 12, 12, 200, 200},{200,216,99, 1, 12, 12, 0},{250,250,99, 99, 20, 12, 12},{500,500,99, 99, 18, 0, 0},{99, 12, 12, 200, 200, 200, 200},{200, 99, 99, 99, 12, 12, 200},{99, 10, 12, 12, 200, 200, 200},{99, 20, 99, 99, 12, 12, 200},{111, 99, 99, 12, 12, 99, 200},{99, 200, 99, 99, 1, 200, 200},{15, 15, 99, 99, 200, 200, 200},{1, 99, 200, 99, 12, 12, 200},{29, 12, 99, 12, 99, 29, 12},{50, 99, 99, 99, 225, 99, 200},{500, 99, 99, 97, 150, 99, 200}}
ctrlColor={{PURPLE,PURPLE,PURPLE,PURPLE,PURPLE,PURPLE,PURPLE},{WHITE,RED,PURPLE,PURPLE,PURPLE,PURPLE,PURPLE},{WHITE,WHITE,WHITE,RED,RED,RED,PURPLE},{PURPLE,PURPLE,PURPLE,PURPLE,GREEN,GREEN,PURPLE}}
