Electra One Mini, latest firmware 1.4.3.
When you use “Send to Electra” and you’re zoomed into an object on the mini (envelop, xy pad, etc), it locks up the unit and needs to be power-cycled to return to normal.
Can you share the URLs of the presets? If they are not public, send them to me using the PM. Thanks!
I have also sometimes this behaviour on MkII when a V Fader window is open!
Hi Martin, I just reproduced this.
Steps
@HDV @zenmonkey it is the same issue in both cases. The detail window loses the “data” when the new preset is received by the controller. I will fix it by closing the window before opening newly received preset.
Resolved now.
