MK2 unresponsive after update attempt
Hi there.
I tried to update to the latest firmware 5 but the unit froze with a stationary update bar and said ‘updating firmware’ I held the rear right button while re plugging the usb but now the unit seems dead, I get a small screen flash when I plug the usb in but that’s it. Any suggestions? Thanks.
are you able to open the bootloader? ie. start the controller with the bottom-right button pressed? If so, what version of bootloader do you have? (v1.0 or v1.1)
Hey there. It was an old boot loader, chat gpt told me what to do so all sorted! Thanks.
@stratblue good that you sorted it out.
It would be great if you could share how you did it, in case somebody else encountered a similar problem.
Good idea. I started up holding the bottom right button, installed the 4.0 OS which allowed it to work again, used the editor site to update the bootloader to the newest version which then allowed me to install the OS 5.
